pietch Posted January 28, 2008 Report Share Posted January 28, 2008 The 1.4 TDI users an 02R box which has an 02J bell housing on some eversions such as the EWR so an 02M 6 speed may bolt up.Apparently the Golf GT TDI (with the AJM engine) gearbox (code DRW) should fit the Lupo and Arosa TDI's as the bell housing (O2J) is the same!However as part of the mods the following parts would also be required, the only problem/ question is the drive shafts and extra 15/20 kg of weight! I am also unsure of gear ratios?Parts needed:?DRW O2M boxdriveshaftsflywheel and clutchstarter motortop gearbox bracketgearbox mountselector unit and cablesvarious stretch boltsthe flange size on the 6 speeds is larger than the 5 speeds hence the need for shafts, you may be able to change your inner cvs on your shafts. This I dont know.Has anyone done this or can anyone advise help? Quote Link to comment Share on other sites More sharing options...
watkins4378 Posted January 29, 2008 Report Share Posted January 29, 2008 Hi Pietch,An interesting couple of posts, thanks.I appreciate the advantages of a 6 speed box but i think with the extra torque and a smooth, progressive remap 5 speeds is enough. Also, very little weight to pull.I think the g60 gearbox is similar as have looked at jabba/ peloquin lsd.Was it teflon tom that had the 142bhp 1.4 tdi as i think he blew it upIn terms of the costs of the mods for extra 30bhp - Iam looing for 40-60 bhp but am going to be guided by allards as am especially concerned about crankshaft flex.pd130 injectors - 150 2nd handhybrid turbo - standard turbo is gt15 ( not gt12?) with 17/44 spec - 400larger intercooler - 700fitting - 300- 400custom remap - 450clutch upgrade - 300lower comp piston and conrods - not sure as runs 19"1 same as pd150ibiza cupra tdi air intake 40 (maybe bmc cda)Plus money on brakes, suspension, atb and roll cage -eventually.Plus point is a 60k mile 2001/2 arosa tdi is around 2500- 3000The idea is similiar to talon sports metro 1600 vvi track day car with mot, see link hereSo if they can modify a rover metro for grueling track day thrashing for a modest cost - anything is possible!CheersThe 1.4 TDI users an 02R box which has an 02J bell housing on some eversions such as the EWR so an 02M 6 speed may bolt up.Apparently the Golf GT TDI (with the AJM engine) gearbox (code DRW) should fit the Lupo and Arosa TDI's as the bell housing (O2J) is the same!However as part of the mods the following parts would also be required, the only problem/ question is the drive shafts and extra 15/20 kg of weight! I am also unsure of gear ratios?Parts needed:?DRW O2M boxdriveshaftsflywheel and clutchstarter motortop gearbox bracketgearbox mountselector unit and cablesvarious stretch boltsthe flange size on the 6 speeds is larger than the 5 speeds hence the need for shafts, you may be able to change your inner cvs on your shafts. This I dont know.Has anyone done this or can anyone advise help? Quote Link to comment Share on other sites More sharing options...
Nadeemaashraf Posted February 19, 2014 Report Share Posted February 19, 2014 Any progress? Quote Link to comment Share on other sites More sharing options...
