MattyB Posted August 12, 2003 Report Share Posted August 12, 2003 Any of you guys got problems getting your wheel geometry back in line since you had your suspension upgrades?Took mine into VW today to have it all sorted, but they cant get it back into line. They reckon either the kit isn't right for the car or it requires specific settings. Currently sitting at...[b:post_uid0]Front Left[/b:post_uid0]Camber 1.42Toe 1.46[b:post_uid0]Front Right[/b:post_uid0]Camber 1.32Toe 0.03Camber is meant to be between -0.5 and -0.10 and the toe between -0.05 and 0.05Whats everyone else at? Quote Link to comment Share on other sites More sharing options...
twisty b-road Posted August 12, 2003 Report Share Posted August 12, 2003 Can't remember what the toe was set to, have the printout at home and can find later if you wantI asked for negative camber, and they set mine to left -1.35, right -1.43.Toe and (whatever the other setting is, can't remember) were set as standard or near as dammit. Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 12, 2003 Author Report Share Posted August 12, 2003 Yeah its just the one side thats out...other setting is caster, but I cant remember what that actually is... Quote Link to comment Share on other sites More sharing options...
twisty b-road Posted August 12, 2003 Report Share Posted August 12, 2003 Mine is set toCaster: left 2.30 and right 2.35Toe: left 0.0 and right 0.3 (!)Camber: left -0.36 right -0.43 (I'm sure they did it -1.36 and -1.43, must be the Alzheimers again)On their computer the specs said (bearing in mind it's not VW saying this)Caster 1.50 to 2.50Camber -0.50 to -0.10Toe -0.5 to 0.5 Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 12, 2003 Author Report Share Posted August 12, 2003 Those tolerance levels are the same as VW had....But according to the EVO boys, about -1.0+ is ok and improves turn in...Its just the rogue 1.4 degrees on the toe that getting to me... Quote Link to comment Share on other sites More sharing options...
