Spluttering & jerking between 1000 rpm & 2000 rpm
thehammer
As the title says my GTI is picking up very badly! It's kinda spluttering between 1000 rpm and 2000 rpm but anything above that it is fine.
Has anyone any ideas what it could be? Im not sure if there has been a thread on here before on this?
I have a K&N filter on, could it be dirty or just crap when it's cold? Can't see that anythings worked loose!
Any comments appreciated!
Cheers Hammertime
does this only happen when its cold?
90% of gti's are jerky when cold.
there was a thread about this a bit back.
apparently you can buy a new part/sensor or something to cure it
dont panic though, its a common problem smile.gif style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />
have a looksie at the filter then, maybe it wants a good clean.
maybe it just wants a bmc laugh.gif style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" />
Also check the throttle body is nice and clean and not sticky - low revs means it only opens a little bit which if its gunked up a little will cause the problem you have described.
HT leads will be worse (if they are gone/going) under load at 1-2000 rpm but would also give the odd blip and oddness at all revs, not just lower.
Make sure you dont have any leaves blocking any air intakes!
Why do you drive at 1-2000 rpm, always assumed my gti would be unstable at that RPM biggrin.gif style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" />
Cheers guys , Im gonna swing by my local specialist in a bit and see what he thinks! It's only just happened in last 3 days so I'm not putting it down to the GTI 'quirk and niggles as standard.'
Yeah Damo could do with a BMC... hint hint ....ile throw in my fully formed ' not cut to pices engine cover for yours'
Hammertime
<{POST_SNAPBACK}>
I thought the throttle body for the GTI was enclosed and couldn't be cleaned?
Nar mate, take off your airbox, and you'll see it wink.gif style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />
<{POST_SNAPBACK}>
I thought I'd read somewhere it was enclosed? Is carb cleaner still the best thing for it?
Ah well, if replacement HT leads don't cure my "jumping" problem I'll give this a whirl.
UPDATE:
Took my car into a specialized electronics/engine garage.
They did emmissions reading and Engine management.
Found out it was a missfire in cylinder 3.
But the guy said there equipment couldnt pin point whther it was the sparks, HT lead for cylinder 3, coil or distributor.
Knew I should have gone with a mobile tester who would have had a fancy laptop!
I had to suggest them change plugs 2 and 3 round and then re-test that way we could see if the problems changed cylinders and if it didn't it wouldn't be the plug. ( he went' oh yeah thats a good idea???? - doh!!!!) He popped my engine cover on and took it for a test drive , then I did , and the jerkyness had gone. So really he's not done anything to it, I should probably have done all that but I know for the future. They dont charge for a second test so might just see if it has been fixed. Still doesnt feel exactly how it used to or maybe its in my head!
Oh yeah it cost me £29!
Hammertime
Balls!! angry.gif style="vertical-align:middle" emoid=":angry2:" border="0" alt="angry.gif" /> I spoke to soon. . . . . . it was pi55ing it down on the way home from the gym tonight and 10 minutes into my journey home it started again . . . coughing and spluttering, check light came on, didn't sound good either . . . . looks like a trip to my garage is in order . . .
I have already changed the HT leads which hasn't worked, when I changed them I also checked my airbox - which was free from any large leaves. I think I spotted the throttle body too - is it far right inside the airbox? and the 'butterfly' bit being the round flappy thing? It wasn't sparkling clean when I took a look - but it wasn't exactly dirty either . . . . if I do clean it which bit do I need to clean - the round flappy bit? or something else? and is it easy to remove it fully (a la tdwindustries) to clean?
Same problem here although it has got better recently. It started after a service so it might be a plug. May let my revs drop a little lower tonight and see what happens....Nice to have all the things above to try now smile.gif style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />
I wouldnt speculate any more on this - if you have tried all above then get it on VAG COM or similar and see what it throws up - these are also symptons of a dodgy sensor somewhere. Has it put any lights on the dash?
To clean the TB you just whip off the airbox, get someone in the car to rev it up and spray some carb cleaner into the TB whilst its moving, a few times. This should free it up, dont remove the TB unless its really black in there!
I got some carb cleaner and gave the throttle body a clean - it was actually 'quite' dirty as the carb cleaner really worked wonders - I could eat of it now (if only the carb cleaner wasn't so toxic). So far so good . . . . time will tell . . . .
