Nealie Posted August 31, 2005 Report Share Posted August 31, 2005 HIHaving had a mate struggle to get out of my driveway last night in his Loop.....i think my plans of coilovers for our Sport have to go on hold. But i still want the baby to handle better. Sooooooooo.............was thinking........Koni TA Shockers All RoundH&are Lowering SpringsAnything else worth doing while it's up on axle stands? Are they easy to swap or is summink gonna prove a right pig to do?That and a BMC induction kit, removing the front and rear chome badges and at some point a set of Schmidt Modern Lines....think that'll just about do it.cheers all Quote Link to comment Share on other sites More sharing options...
RobinA3 Posted September 5, 2005 Report Share Posted September 5, 2005 i'd go for a matched set of dampers and springsthe way you are doing it won't give the best performance as the springs are not matched to the dampersfor best results you should use the same make of damper and springs or a shock and spring set up like spax or gmax for example as they have been designed to work together to give the best ride and stiffnessmight be worth changing the top mounts if you feel like it Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted September 5, 2005 Report Share Posted September 5, 2005 lupos have some funky bolt sizes so watch out when you attack the car wit a spanner. Quote Link to comment Share on other sites More sharing options...
