wkpaul Posted November 23, 2023 Report Share Posted November 23, 2023 (edited) I recently discovered oil in the air filter and throttle body, I got a cool catch can but am not sure where the best place is to mount it. is it best to block off the air filter or connect the catch can back in. thanks in advance Edited November 23, 2023 by wkpaul Quote Link to comment Share on other sites More sharing options...
saint francis Posted November 24, 2023 Report Share Posted November 24, 2023 Hi, apologies if this is not relevant for you but I thought I'd mention I had the same problem with oil contaminating the air filter and causing emissions problems. Turned out not to be piston rings but instead, simply way too much oil in the engine. Basically it recently had an oil change before I bought it and it was significantly overfilled which caused the problem. I let out some oil to the normal level, changed the air filter and solved the problem. Quote Link to comment Share on other sites More sharing options...
wkpaul Posted November 24, 2023 Author Report Share Posted November 24, 2023 Thanks , I just got the car recently and there was loads of oil in the filter and throttle body , ive cleaned it all out and changed the oil , going to keep an eye on it but had loads of other issues so trying to eliminate all the causes I can, cheers Quote Link to comment Share on other sites More sharing options...
