Emil Pisarenko Posted April 23, 2023 Report Share Posted April 23, 2023 Good afternoon I have a VW Lupo 3L 2001. While driving, the car stalled. Numbers flashed on the transmission display. After that, the car would not start. After cleaning the battery terminals, the car started. But after 700 meters, the first gear did not turn on at the traffic light. It turned on, but the car just did not go. The box began to work strangely. With strange sounds. I didn't get to go. Now the car starts only if you remove and put the battery terminals, or after a long break. Runs once. After that it won't start again. Again, you need to do something with the terminals. Also the box does not include gears. No matter what position the automatic transmission selector is in, the car is always in neutral when the engine is running. I cleaned the battery from oxides. Looks like an electrical problem. Tell me, please, what can it be? I will be very grateful! Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 23, 2023 Report Share Posted April 23, 2023 Read https://forums.clublupo.co.uk/index.php?/topic/107754-lupo-3l-not-starting-at-all/#comment-1203926 Quote Link to comment Share on other sites More sharing options...
