Gdog Posted March 16, 2020 Report Share Posted March 16, 2020 Hi All, new to this forum but wondering if anyone knows the correct nut size for an 07 Fox track rod end. Just changed the silent block bushes, that's fun, heres a tip for anyone trying the same, I have an inserting tool but kept splitting the block end just through the force needed to insert it, I ended up using a jubilee clip wrapped around the insert tool and block end to stop it splitting, this meant I could wind the block fully home using the insert tool. Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 17, 2020 Report Share Posted March 17, 2020 Not sure about Fox but pretty sure lupo is 17mm for the steering balljoint nut and 22mm for the track rod lock nut, I used 7/8 spanner as dont have a 22mm open ended one for that or else use adjustable spanner etc. Quote Link to comment Share on other sites More sharing options...
Gdog Posted March 17, 2020 Author Report Share Posted March 17, 2020 Thanks, was trying to confirm if its an M14 with 1.5mm thread, its the ball joint pin nut i'm replacing. Quote Link to comment Share on other sites More sharing options...
