anthonyc1988 Posted May 14, 2017 Report Share Posted May 14, 2017 i've just purchased a seat arosa 04 however having issues with the head unit the previous owner butchered the old original plug so pretty much left with the wires that i need to match to an oem iso plug i'm unsure what wires i need to use. i have the following. thick red thick brown black green/ white grey/ white blue/ grey red/ brown also does anyone know the locations for the stereo fuse so i can check that as well Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted May 15, 2017 Report Share Posted May 15, 2017 the duel colour are most likely speakers, to work out what goes where stick you multimeter onto ohms connect one wire to the multmeter and then just touch the other wire, one of the speakers should crackle thick red is most likely the permanent live, you just need to work out which of the other wires goes live with the igntion on, which will leave the last wire as ground its pretty easy with multimeter Quote Link to comment Share on other sites More sharing options...
anthonyc1988 Posted May 19, 2017 Author Report Share Posted May 19, 2017 thanks for the reply i managed to sort it got another iso block and pins they just fitted them in the correct order that i found online and now working a treat Quote Link to comment Share on other sites More sharing options...
