Hi guys, just after some help, just bought some bbs rx2 wheels for my lupo, and I've seen on other threads that I'll need to buy different bolts to make them fit, if this is the case does anyone know which bolts?
cheers, Ollie
Should be radius heads.
You may need longer if you are going from steels to alloys
Take one of your wheel bolts and pass it through the RXII. If you can see more then the the radius of the threaded part out of the back of the wheel (in this instance 12mm+); then you will be fine. If you see less you will need longer bolts.
1 hour ago, Danyutz said:
I have the same wheels, you will be fine with standard bolts, mate. I use the same bolts on alloys and winter steelies.
Cheers guys, I'll try and see if a standard bolt will fit when I get the tyres on them, but if not, the only difference will be length?
