Bozwurt95 Posted July 14, 2016 Report Share Posted July 14, 2016 I've recently bought a lupo gti with a 6 speed gearbox! A few days ago my clutch pedal got stuck to the floor and wouldn't let me change gear, it popped back up again but still wouldn't let me select a gear! I had to get towed home and the guy who towed me asked what happened so I told him and he told me to replace the slave cylinder, I've done this and bled the system but I still can't select any gears while the engine is running and while the engine is running the clutch pedal has a slight engine vibration half way down when pushing it! Does anyone know if it could be the clutch master cylinder or the clutch itself? Or maybe even something else? Quote Link to comment Share on other sites More sharing options...
wehey Posted July 15, 2016 Report Share Posted July 15, 2016 Slacken off the bolts on the slave cylinder and see if you can see the piston moving Quote Link to comment Share on other sites More sharing options...
Bozwurt95 Posted July 17, 2016 Author Report Share Posted July 17, 2016 Turned out the be the actual clutch! Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted July 23, 2016 Report Share Posted July 23, 2016 A little worn, prolly best to replace Quote Link to comment Share on other sites More sharing options...
