randommandan Posted April 12, 2016 Report Share Posted April 12, 2016 (edited) can you fit pop out windows on a vw lupo 1.4 e? Edited April 13, 2016 by randommandan Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted April 13, 2016 Report Share Posted April 13, 2016 You can fit them to any Lupo as long as it has the fixing in the B pillar, you can add them in but it's a more complicated job 1 Quote Link to comment Share on other sites More sharing options...
christophertr6 Posted April 13, 2016 Report Share Posted April 13, 2016 I fitted them to my GTI which did not have the fixings in the B pillar. I bought the blind nuts from VW dealer (about £1.25 each). You have to drill the B pillar to accept these fittings. They are hexagonal in section behind the flange. I found that drilling the hole slightly undersized then tapping the fixing into the hole and giving it a slight turn (literally 5 or 10 degrees) with pliers locked it in place. It does not seam enough but it has worked for me. To set out the correct position of the holes I used my other car as a pattern - which is not too helpful for others I know! I think I have a photo of the holes I drilled which will indicate their position - they are not right in the middle of the depression in the B pillar metal so beware. 1 Quote Link to comment Share on other sites More sharing options...
randommandan Posted April 14, 2016 Author Report Share Posted April 14, 2016 will these be the fixings? Quote Link to comment Share on other sites More sharing options...
christophertr6 Posted April 15, 2016 Report Share Posted April 15, 2016 Yup. That'll be the ones. Easy job. Main task will be cutting out the old windows. I used welding wire as a Cheese Wire cutter. Take car is I did manage to smack myself in the face. 1 Quote Link to comment Share on other sites More sharing options...
