adro Posted February 2, 2015 Report Share Posted February 2, 2015 Bought myself a 1.0 lupo but it is sputtering a bit on low revs. Have read here it could be plugs and leads so I'm going to change both. Just wondering what type/brand are best to use?Also is there anything else I should look at that might be causing the problem.Forgot to mention, my temperature gauge doesn't seem to move on the dash, could this be part of the problem? Quote Link to comment Share on other sites More sharing options...
danoid Posted February 3, 2015 Report Share Posted February 3, 2015 Plugs: NGKLeads: OEM or very good quality, cheap ones tend to not last long!You may need a new coolant temperature sensor, only a couple of quid, but you will need new G13 coolant and a new o0ring for the sensorAs when you remove it, if your ninja like you can put the new one back in, but best to let it drain out and put new coolant in. It's not a thorough drain but good enough. Quote Link to comment Share on other sites More sharing options...
adro Posted February 9, 2015 Author Report Share Posted February 9, 2015 Thanks, changed the temperature sensor and it has solved both problems. Haven't got around to doing the plugs and leads yet but it's on the list. Thanks again Quote Link to comment Share on other sites More sharing options...
