reym Posted November 24, 2014 Report Share Posted November 24, 2014 Hi guysJoined here as the mrs has an 1.4 Arosa, and having a couple of issues - thought I'd see if you guys had any ideas? We seem to be getting a lot of condensation in the car, are there any typical leak points - rear washer is fine, I know they can leak.How easy are the doors to adjust? They've got a very slight drop.Will post these elsewhere when I find the place!ThanksMatt Quote Link to comment Share on other sites More sharing options...
Rich Posted November 24, 2014 Report Share Posted November 24, 2014 If you think the leak is external just hot box the car and look for where the smoke is coming out.As for the doors, if you're going to consider adjustuing them then you should investigate the hinges, once you look at these you should think about how to adjust them and then do so, it is pretty easy. Quote Link to comment Share on other sites More sharing options...
