Would Gti wiper arms fit standard Lupo's
Rookwise
Just wondering if the front wiper arms from a Lupo Gti would be a straight fit to the non gti's.
Are the thread's/diameter's the same ?
Would they need modifing ?
Prices/part numbers (including blades) ?
Any info would be helpful. I'm assuming that the arms are bolted onto the car. I know that the Gti arms follow a different line across the windscreen to the standard ones. Is there anything else I need to know before doing the conversion ?
Both wiper arms fit straight on. Tigz has my old style Gti arms (aero blades but with different blade retention clip design) on his car as I got the new style arms when I bought new blades.
Cheers.
Any idea how much the arms are to buy including the blades and all fixings ?
Also. I dont suppose theres any pictures of how they fit ?
Is the rear wiper on the Gti the same type as the standard Lupo's or is that also different ?
They are not cheap.
I had to buy a new arm and was forced to buy a new blade as well.
I dont know if thats changed at all?
Think they could have been around £50 a side?
Rear wiper is the same.
Polo rear wiper fits though.
£50 a side ohmy.gif style="vertical-align:middle" emoid=":o" border="0" alt="ohmy.gif" />
Bloody hell.
Is that just for the arm or does it include the blade as well ?
Cheers Andi. Think I'll look into it in a few days when me overtime is paid tongue.gif style="vertical-align:middle" emoid=":P" border="0" alt="tongue.gif" />
Do the standard arms just unbolt and then you pull them off ?
They pull off.
Cant really explain how, cos I dont know.
Even after the first side it still took five minutes to do the other side.
Theres a bit of a trick to it, that unfortunatly I dont know it wink.gif style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />
If they just pull of that would mean there would be a cog type peg holding the arms on.
Wriggling them side to side while pulling should remove them.
The front wiper arms are held on the drive splines by a nut. To get to the nut you have to praise off the black plastic cover that is over the nut. The cover has a small slot in it to allow it to be praised off with a small flat blade screwdriver (dont slip and scratch paint here).
Think the wipers are £43 for arm and blade (new style like I have got but nearly identical to original style just slightly different clips to hold the blade on the arm).
Rear wiper is identiacal on all Lupo's as Tigz's said.
