My_Names_Buck Posted September 21, 2006 Report Share Posted September 21, 2006 Hmmm.. I'm very confused, (angry) style="vertical-align:middle" emoid=":angry2:" border="0" alt="angry.gif" /> I noticed this the other night while out driving. For some reason my rev counter is incorrect the needle is around 2500rpm to high. Even with the engine turned off and keys removed it still indicates 2500rpm Right through the rev range the needle is 2500 ahead of what it should be. It went all the way around to the 90 degree mark on the temperature gauge last night.Performance has not been affected and the engine still apears to be runnig the way it should be and still idles as before but the indication is totally wrong.Any help would be greatly appriechiated.Sam. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted September 21, 2006 Report Share Posted September 21, 2006 the clocks need to be removed it would seem from what you have said that the needle may have moved on the spindle, the clocks pull up over once the binnacle has been removed1. pull the outer binnacle forward out of the clips2. the inner binnacle is held in with 3 torx bits3 the clocks have 3 torx along the top4 disconect the battery wait 30mins, unplug the purple and the blue multiplug5 dissasemble the rear from the clocks again torx bits until it seperates open 6 gently pull the needle out using the centre piece as a place to grip7 place back on in its correct position.hope this helps style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
My_Names_Buck Posted September 21, 2006 Author Report Share Posted September 21, 2006 the clocks need to be removed it would seem from what you have said that the needle may have moved on the spindle, the clocks pull up over once the binnacle has been removed1. pull the outer binnacle forward out of the clips2. the inner binnacle is held in with 3 torx bits3 the clocks have 3 torx along the top4 disconect the battery wait 30mins, unplug the purple and the blue multiplug5 dissasemble the rear from the clocks again torx bits until it seperates open 6 gently pull the needle out using the centre piece as a place to grip7 place back on in its correct position.hope this helps style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />Cheers for this info mitch. i'll give this a whirl tomorrow after college. Really messes with ya head when driving i'll tell ya. I Keep thinkin i'm cainin the boll*cks of t all the time. style="vertical-align:middle" emoid=":blink:" border="0" alt="blink.gif" /> Quote Link to comment Share on other sites More sharing options...
My_Names_Buck Posted September 23, 2006 Author Report Share Posted September 23, 2006 Sorted cheers. Quote Link to comment Share on other sites More sharing options...
