pnzarosa Posted March 10, 2014 Report Share Posted March 10, 2014 hiI've had my arosa for a year but took it for the mot and it is running rough on idle so can't get through the emissions.I've changed everything i can, distributor cap and rotor arm, plus and leads, coil pack, lambda sensor and a new exhaust from cat back.the garage had a look and it is down on compression on one cylinder.now they said it would be £300+ to have a look and then either sort the valves or head gasket which ever it is.but i thought wouldn't it be as easy and cheap for me to swap the engine for a different one?it is a 1999 1.0 8v aer engine code.looking on websites they aren't very readily available, can i use a 1.4 8v?from reading posts any 16v will have to have all the ecu and such like and i just want to do it as easy as i can after fixing all the brakes for the mot as well.i don't want to just scrap it as it is such a good car in all other respects. love the neon yellow colour and its only done 69k.any thoughts would be very helpful, thanks Quote Link to comment Share on other sites More sharing options...
