Hi. :)
I can't get the boot of my 2001 Arosa S open. The central locking won't unlock it it although it does make straining motor noises for a second or two when the car is locked or unlocked.
Similarly, I can't get the key to rotate properly in the lock, and any rotation that does happen doesn't seen to do anything. I've not been able to use the key in the boot since I've owned the car though, so that's not new. The actual boot handle it self doesn't have much resistance to movement, it moves smoothly and springs closed when I let go, but it doesn't actually feel as though it's connected to anything mechanically. I can't remember what it felt like before, it might have always been like that.
I've read that some of the VAG boot locking mechanisms are prone to jamming and need cleaning and lubricating periodically, but to do this I presumably need to get the bugger open.
Anyone got any ideas? Would it be worthwhile to pull the interior plastic panel off of the boot from the inside of the car?
Ta :)
EDIT: got the interior trim off and had a poke about, the problem did indeed seem to be that parts of the mechanism were sticking enough to prevent them from springing back to where they should be. Also the white electronic actuator seems to be completely dead now, so until I manage to track down a replacement I've unhooked it from the manual locking mechanism.
Edited by Tango91
