jacksonbubblethwaite
Main beam issues 01 lupo s
Hi all, perfect weather for driving! (if i had air con), MOT coming up and my headlights have started playing up, have changed bulbs but still having problem. Side lights and dipped headlights work fine but main beam will not work on drivers side, any ideas as i have changed bulb and it is not that simple sadly :(
cheers in advance,
Mike
Does its oak if you try and flash rather than keep them on
Still fails to work on drivers side when flashing, its a puzzler, also noticed the main beam indicator light on instrument panel no longer comes on either
ps. thanks for the reply!
Edited by jacksonbubblethwaite
Could well be the stalk itself, they are a semi common failure, usually with indicators though
fell like a right banana! had my indicator stalk changed about 2 months ago and the auto electrician had not put a fuse back properly, pushed it in and it works like a dream, thanks for your kind help though mate, hope i can repay the favour one day! i never would have thought that there would be separate fuses for each main beam but i guess it makes sense, can book the mot now and keep my fingers crossed! poor lupo getting old now!
