Dblock Posted April 16, 2013 Report Share Posted April 16, 2013 Hi guys, Looking for a little bit of help on a 1.4 tdi. If anyone has pics great but even a rough guide would be nice. Does anyone know how to take off the inlet manifold? I just want to take it off to give it a good clean out same with the EGR valve. Will I be ok take the vacuum pipe out of the EGR valve too? When I did a search there is alot of conflicting advice. Thanks for any advice guys, always appreciated. Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 17, 2013 Author Report Share Posted April 17, 2013 No one removed the inlet manifold? I assume that other vags like fabia and polo share the same engine as the 1.4 tdi lupo/arosa? Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 17, 2013 Author Report Share Posted April 17, 2013 Taken from a user called Raikky on clubpolo1. spray penetrating oil on the 2 nuts which clamp the egr pipe to exhaust manifold then remove. maybe you will need nut/bolt removers.2. remove other 2 bolts which clamp egr pipe to egr housing. discard gaskets3. pull egr pipe away4. remove inlet elbow from manifold and IC pipe from IC to elbow hose.5. undo the 3 bolts which secure the egr housing to manifold. then pull egr housing off.6. 4 bolts secure manifold to head. remove these then pull off manifold.7. clean out manifold8. put everything back in reverse order using new gaskets and nuts.Does that sound about right? Quote Link to comment Share on other sites More sharing options...
