keiron greenaway Posted April 4, 2013 Report Share Posted April 4, 2013 hey guys.. seems to be an invisible problem with my motor 10 mpi. only got the engine for another two months but need it to run around on until i lupo gti it .. im loosing water badly now.. ive had pressure test on two occasions to rule out head gasket and also checked the oi for mixture with water nothing there. also had a die put through to see for any leeks. now i changed all pipes and jubilee clips and sealed all pipes correctly. don't know what else it could possibly be . and also dont seem to be any abnormal amounts of steam coming from the exhaust or car doesn't over heat :/ anyone got a clue ? Quote Link to comment Share on other sites More sharing options...
Lenry Posted April 5, 2013 Report Share Posted April 5, 2013 Il'll be very interested to know what you find as I have a similar issue. Just has to top up a the coolant after a new radiator and head gasket.Replacing the coolant temp sensor this weekend as it is not giving correct readings. Quote Link to comment Share on other sites More sharing options...
