brake issue, related to pedal box. HELP
Guys, help needed.
Pedal box went on arosa. Used guide on forum to replace. Now the brakes wont release. the pedal wont return to its 'proper' neutral position. So ive had to take the whole f-ing thing back out again. Now before I attempt to refit it, I want to know if this is likely to be a spring issue on the pedal. ie, do i have to position the spring on the pedal in a particular way on the box? Or have i knackered the brake servo when pulling the pedal of its clip?
Doing the job twice is bad enough, i want to make sure of the remedy before i have to do it 3 times!!
thanks in advance,
Matt
