STi Posted August 8, 2011 Report Share Posted August 8, 2011 Hello.It looks like I need to change my clutch in my Lupo.The clutch is fine but when I depress the clutch pedal the bearing in making a right noise, It drives fine and there is no other problems.I was just wondering if there is anything special I need to do or know before I change it ?Any help would be appreciated.Sie. Quote Link to comment Share on other sites More sharing options...
dublove89 Posted August 8, 2011 Report Share Posted August 8, 2011 No there is nothing special or complicated Sie, the only problem i had was i struggled with the lack of space whilst working under the car. Next time the engine will be coming out as i think it would be less hasstle than struggling under the car. The only reason i changed my clutch was because i was replacing the gearbox. IMO i wouldnt bother changing your clutch yet if the only problem your having is a noisey release bearing.Hope this helps,Mark Quote Link to comment Share on other sites More sharing options...
STi Posted August 9, 2011 Author Report Share Posted August 9, 2011 Thanks Mark.I think I will take your advise and leave it till the clutch goes.Cheers.Sie. Quote Link to comment Share on other sites More sharing options...
