Liam13o3 Posted August 23, 2010 Report Share Posted August 23, 2010 (edited) Hello,Probally seen ive made alot of thread on different wheels etc..Well finally got some..Just 1 problem is im not sure // useless when comes to wheels..I think there off a 944.. Heres a picture. I have no clue about offsets etc, so if someone could tell me? And maybe Link the Adapters ill need?Only thing i can see on them is 8 52 on two of them and other two says 6 52.Also will i need 20mm spacers aswell? + Adapters, and require my Arches to be rolled?The tyre sizes are215/40R16 86W // 195/40R16 80WAlso they need refurbing, so got a few ideas in mind..Baby Blue centres with Chrome lip? To match interior + be different.Gloss Black centres with Chrome lip?Full Chromed.Thanks in advance for help! Edited August 23, 2010 by Liam13o3 Quote Link to comment Share on other sites More sharing options...
Liam13o3 Posted August 23, 2010 Author Report Share Posted August 23, 2010 Fount theses ..http://www.wheelenhancement.com/index.php?t=WheelDetail&id=27http://www.wheelenhancement.com/index.php?t=WheelDetail&id=28 Quote Link to comment Share on other sites More sharing options...
R99 Posted August 23, 2010 Report Share Posted August 23, 2010 (edited) With the info you have posted then the offset is ET52 and your wheels are 6J for the front and 8J for the rear....With a set of 20mm hub adapters fitted then your FINAL ET will be 32 for both the front & rear, although obviously the back will stick out more being 2" wider than the fronts. Your fronts (with adapters) will go on no bother at all! (I run 7J & ET 27 and coilovers with no rubbing!) Rears will be touch and go I think! (I run 7J & ET 25 on the rear and do get mild scrubbing with rear passengers)Use willtheyfit.com to calculate it all for you! Edited August 23, 2010 by R99 Quote Link to comment Share on other sites More sharing options...
Philplop Posted August 23, 2010 Report Share Posted August 23, 2010 They're D90'sI take it you mean polished, rather than chrome? Quote Link to comment Share on other sites More sharing options...
Liam13o3 Posted August 23, 2010 Author Report Share Posted August 23, 2010 With the info you have posted then the offset is ET52 and your wheels are 6J for the front and 8J for the rear....With a set of 20mm hub adapters fitted then your FINAL ET will be 32 for both the front & rear, although obviously the back will stick out more being 2" wider than the fronts. Your fronts (with adapters) will go on no bother at all! (I run 7J & ET 27 and coilovers with no rubbing!) Rears will be touch and go I think! (I run 7J & ET 25 on the rear and do get mild scrubbing with rear passengers)Use willtheyfit.com to calculate it all for you!Thats ace man!Just what i was looking for! ..Could you pop me a link to the Adapters id require please?Also they come in sets of 4 normally?Will i need buy 8 now? As different for front // rear? Quote Link to comment Share on other sites More sharing options...
Liam13o3 Posted August 23, 2010 Author Report Share Posted August 23, 2010 They're D90'sI take it you mean polished, rather than chrome?Yeah i meant Polished But thinking Matt Black, with Polished lip would look pretty sweet.. Quote Link to comment Share on other sites More sharing options...
Philplop Posted August 23, 2010 Report Share Posted August 23, 2010 Adapters come in pairs, so you can choose different widths if you want. Quote Link to comment Share on other sites More sharing options...
Liam13o3 Posted August 24, 2010 Author Report Share Posted August 24, 2010 Ahh right ok mate, could you link me ones your'd recommend for my wheels? Please. Quote Link to comment Share on other sites More sharing options...
Reed Posted August 24, 2010 Report Share Posted August 24, 2010 You'll need 4x100>5x130 adapters, those tyre sizes are gonna pose a problem I should imaginePut the 195/40's on the 8's probably and a 165/40 or something like that on the 6's and you should be scrub free Quote Link to comment Share on other sites More sharing options...
