vdubgti Posted May 24, 2010 Report Share Posted May 24, 2010 Hello allMy front windows wont go down with the driver side remotes, they work goin up but not down, i checked all the fuses which are all fine, even checked to see if the connection was loose, which it isn't. when i click the buttons up i can hear it "click" as if to say the windows will work goin up, but when i click down i hear nothing.Do i have faulty buttons? surly they both cant stop working at the same time??cheers for any useful info. Quote Link to comment Share on other sites More sharing options...
s2000king Posted May 24, 2010 Report Share Posted May 24, 2010 I have the same problem in my Polo, would be interested to hear the answers to this... Quote Link to comment Share on other sites More sharing options...
phodz Posted May 24, 2010 Report Share Posted May 24, 2010 Ye same i have a lupo and the drivers side window works perfectly but the passenger side doesn't work at all,, i can hear it trying to work like a click, thats why i think its a loose connection but cant seem to fix it Quote Link to comment Share on other sites More sharing options...
Alan B. Posted May 25, 2010 Report Share Posted May 25, 2010 take the door cards off and make sure no wires have gotten caught first off. do it carefully so you dont break the fragile pins.then check the buttons themselves, take the button surround out and make sure the case of the switch is closed fully as if the little tabs break, the window will only work in one direction as i found the other day.if thats not the case, and the switch is sealed completely, theres a thread on here in the tech section on splitting the switch and cleaning the boards and fragile metal disks.be very very very carefull splitting the switch as you could very easily break the tabs off and be left with a broken switch cse and need a new one regardless. Quote Link to comment Share on other sites More sharing options...
Matt_Matt Posted May 28, 2010 Report Share Posted May 28, 2010 (edited) I discovered that this is a common fault. I had the exact same problem where I can hear the button click but the window wasn't moving. After paying to replace the motor, I found out all it was the runners the window is on sticking. I just popped out the interior door panels and had someone pull the window down (not yank) while I pressed the button and I was told to lubricate the runners now and then (every 4-5 months)to stop it sticking in future. Dashboard cleaner was advised as been the perfect lubricant. I'd give it a try before trying to replace the motor/regulator. I have had this issue on both passenger and driver electric windows and both were the exact same I have to persuade them to work now and then but so far no other problems with them. Edited May 29, 2010 by Matt_Matt Quote Link to comment Share on other sites More sharing options...
EllyMonteforte Posted May 28, 2010 Report Share Posted May 28, 2010 Same problem here. Passenger side window stopped working about a week after I got it. Nothing to do with the fuses or the switch or anything like that....need a new regulator...gutted! Ha. Quote Link to comment Share on other sites More sharing options...
