koolkidnumberone Posted July 1, 2009 Report Share Posted July 1, 2009 Firstly im sorry as im sure this has probably already been discussed but i bout my BMC CDA from kam racing and ive got it int the box ready i'm attempting fitting saturday with little experience!Will i need to cut away some of the big engine cover?Will i need to cut a whole out of my bumper to run the air in?Do you have to do this?Do i need to buy any other parts to fit at the same time?Will the sound be better?Finally im sorry to ask so much but im excited as im sure you can understand. Does anyone have any pictures so i can see what good looks like?Any help much appreciated Michael Quote Link to comment Share on other sites More sharing options...
Guest LupoJoe Posted July 1, 2009 Report Share Posted July 1, 2009 Hi mate, do you have the 90 degree piece of silocone hose etc with it?, if so, fit that to the bmc before you start. Then remove the plastic engine cover, youll see there are around 8 screws in the airbox (some in the side some round the back), once you have removed them lift the airbox off and push the new one itno place, when i did mine i made the bmc face the left like the standard airbox did, i managed to fit the cover back on but wasnt quite a perfect fit. No cutting is needed as you cant tell it doesnt quite sit perfectly. Quote Link to comment Share on other sites More sharing options...
