Arosa FR Posted October 19, 2004 Report Share Posted October 19, 2004 Hi guys, ever had any problems with yer lights fogging up when it rains, damn nuisance :cry: .Is there any way how to prevent the humidity from getting in???? :oops: Quote Link to comment Share on other sites More sharing options...
tom199 Posted October 19, 2004 Report Share Posted October 19, 2004 seal the edges with a silicone like type substance, or clear nail varnish.my rears do the same cause they are aftermarket. but my fronts are fine, your front's steam up? if so I'd get that checked under warranty Quote Link to comment Share on other sites More sharing options...
Arosa FR Posted October 19, 2004 Author Report Share Posted October 19, 2004 I tried to get that changed under warranty, but apparently GermCar won't accept that particular defect as a warranty matter, strangely enough, they consider that as normal, apparently my local Seat dealer had a customer come in with an inch of water in the headlight, when they had removed it, packaged it and sent it to GermCar....well they refused to exchange it with a new one. Puzzling matter :? Quote Link to comment Share on other sites More sharing options...
dj_slipp Posted October 19, 2004 Report Share Posted October 19, 2004 My rears condensed too. Luckily my local Seat dealer sorted mine - but they had sh!t loadsa trouble gettin it to be covered under the waranty. When u seal them with silicone its worth givin them a blast with a hair dryer! Quote Link to comment Share on other sites More sharing options...
mattie Posted October 20, 2004 Report Share Posted October 20, 2004 aye mine do it too, the rear driver's side is the worst, the front ones jst do it at the bottom, its very annoyin though. Goin to take it in to the dealer next week as its under warranty.I wud clean around the joints with a power washer & bleach then dry with a hair dryer before sealing with silicon, theres a drivers rear light on ebay the mo but, prob selling cos its steamin up as with the warranty, i say if it doesnt warn of this in the manual, then its a defect.cheers Quote Link to comment Share on other sites More sharing options...
DanGTI Posted October 24, 2004 Report Share Posted October 24, 2004 i had this prob with my arosa......both the front and rear lamps WILL mist up occasionally but if you get actual bubbles of water in your lenses they are covered under warranty. my seat dealer replaced one rear lens on the arosa and i had to buy the other (as it had a small crack in it). any misting is not covered though as this is considered normal. Quote Link to comment Share on other sites More sharing options...
DanGTI Posted October 24, 2004 Report Share Posted October 24, 2004 oh also should mention with arosa rear lenses, sometimes its just that the lamp needs taking out, the seal being taken out, cleaned and positioned carefully. Quote Link to comment Share on other sites More sharing options...
Arosa FR Posted October 25, 2004 Author Report Share Posted October 25, 2004 Cheers lads for the info.I'll check the sealing, otherwise, I suppose i'll just Have to live with the mist Quote Link to comment Share on other sites More sharing options...
Snoopy Posted October 25, 2004 Report Share Posted October 25, 2004 My left Xenon has just started playing up - gonna be taking it into VW, and won't be taking no for an answer. Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted October 25, 2004 Report Share Posted October 25, 2004 seems common little problem the xenon one Quote Link to comment Share on other sites More sharing options...
Snoopy Posted October 25, 2004 Report Share Posted October 25, 2004 Apparently my Mum had the problem before and they tightened up a seal, so hopefully that simple again. Quote Link to comment Share on other sites More sharing options...
maxxdope Posted January 2, 2005 Report Share Posted January 2, 2005 hey mates spray on some teflon substance ...all the korean and taiwan products is supposed to have the fog effect!!! Quote Link to comment Share on other sites More sharing options...
