Blackrat Posted May 24, 2004 Report Share Posted May 24, 2004 so as you all know we all tripped up to Ross' place to help out Matt aka essexloop fitting his coilovers Ross was the foreman and barked orders out, although `no-one` else seemed to do what he wanted so he fitted em himself border="0" class="linked-image" /> border="0" class="linked-image" />after fiddling for about twenty minutes he realised that the new strut needed certain parts off the old strut border="0" class="linked-image" /> border="0" class="linked-image" />yup using a nut gun us better than ya fingers mate border="0" class="linked-image" /> border="0" class="linked-image" />this is what the fk looks like when you get it outta the box border="0" class="linked-image" /> border="0" class="linked-image" />with the bearing located in place border="0" class="linked-image" /> border="0" class="linked-image" />and the rubber mount border="0" class="linked-image" /> border="0" class="linked-image" />stick it back in the car, replace the top washer and nut border="0" class="linked-image" /> border="0" class="linked-image" />insert them two bolts , lightly tighten and you will feel you can adjust the wheel camber by holding the top and bottom of the disk and pulling either top or bottom , (you will need to take the car in for wheel alignment) once the desired camber is set tighten like Ross does .. tighten till it strips quarter turn back border="0" class="linked-image" /> border="0" class="linked-image" />do the other side border="0" class="linked-image" /> border="0" class="linked-image" />lower the car and admire border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted May 24, 2004 Report Share Posted May 24, 2004 yer forman!!Minty pics matey!! Quote Link to comment Share on other sites More sharing options...
DubDub Posted May 24, 2004 Report Share Posted May 24, 2004 Nice one.... We should start some "how to" guides with pics.... Quote Link to comment Share on other sites More sharing options...
