Jen Posted August 26, 2005 Report Share Posted August 26, 2005 as the title says please style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />cheersJen x Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted August 26, 2005 Report Share Posted August 26, 2005 Should be where they all are. Near the rear offside wheel. Its silver in a holder with pipe going in and pipe going out.. I think style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Jen Posted August 26, 2005 Author Report Share Posted August 26, 2005 cool ill take a look tomorrow, thought id put the engine size just incase they were different positionings!cheersJen x Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted August 26, 2005 Report Share Posted August 26, 2005 they should all be in the same place Quote Link to comment Share on other sites More sharing options...
Jen Posted August 26, 2005 Author Report Share Posted August 26, 2005 is it easy to access and change? im changing the oil too tomorrow so he'll be up on ramps alreadyJen x Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted August 26, 2005 Report Share Posted August 26, 2005 yes easy enough if you can get the clips off and on again... which are a pain in the assyou are supposed to depressurise the fuel system by removing the fue pump relay then start the engine (or try to). Then under the output pipe (closest to the engine)Then take the plastic holder off the car, remove the input pipe, and it slips out. Refitting is the reverse of removing style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> have something to drain the filter into as it will have a lot of petrol in it. I have done it without depressurising and not had a problem (not on the lupo) and also dont worry about fuel pissing out when you take the pipes off as it doesnt (cos fuel pumps not pumping!).have fun Quote Link to comment Share on other sites More sharing options...
Jen Posted August 26, 2005 Author Report Share Posted August 26, 2005 ok cheers! sounds a bit scary but hey ill give it a go!Jen x Quote Link to comment Share on other sites More sharing options...
