pass6n23 Posted February 19, 2023 Report Share Posted February 19, 2023 Hi all I no this is not polo site but I'm not getting much luck on club polo only one guy is helping I have done a ahw to afk swap now I have a ahw in the shed I want to do a 1.6 1 4 hybrid supercharger build I'm following caspers gti lupo build with out pistons and rods m only after 150 165 bhp low boost I will be using a decomp plate 2.8mm and a 0.6mm headgasket should get me around 8.8 9 or a 3mm plate and a 0.8mm gasket for around 8.5 compression might be completely wrong here ecu will be a speeduino Will the 1.4 16v head fit the 1.6 bottom with out modification or is there anything I need it's the same design as the 1.6 gti polo cam wise just hasn't got vvt This is my parts list so far 1mini supercharger and tensioner 2 sheet metal for mount 3 mini supercharger tensioner will need a bigger pulley with edges to stop the belt moving 4 intercooler and piping can use the 1.4 tdi if not uni it is 5 recirculation valve 6 1830mm belt 7 head gaskets and gti head bolts 8 afr wideband kit 9 Boost oil temps gauge 10 Fule pressure regulator I need a wiring diagram so the ecu builder can do his thing if any can help out send pic or link will be grateful polo 6n2 running ahw wiring loom Is there anything else I should get? Thanks all Quote Link to comment Share on other sites More sharing options...
