lukelupo Posted June 16, 2005 Report Share Posted June 16, 2005 can someone just tell me how to get the damn offside wing mirror off cus i have a new one but no idea how to get the old one off! help!!!!! Quote Link to comment Share on other sites More sharing options...
paulbin Posted June 16, 2005 Report Share Posted June 16, 2005 inside there should be the interior cover, give it a good pull that should get it off, then there might be 3 or more screws/nuts holding it in Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted June 16, 2005 Report Share Posted June 16, 2005 do a search - snoopstah posted a how to when mine was ripped off! Basically as paul says pull the inside cover off (you will need a screw driver probably as its got loads of clips)....Then there is a big torx screw that hold the whole thing on - its a big torx... take that off and assembly will drop.Then... under the mirror hosuing is a screw and whole. Undo the screw, then push a flat blade in the whole to release the hosuing.Easy! Quote Link to comment Share on other sites More sharing options...
lukelupo Posted June 16, 2005 Author Report Share Posted June 16, 2005 cheers all sorted, u can read my other post to hear of the pain i went through to finish this! Quote Link to comment Share on other sites More sharing options...
