Trx 33
How to: Correctly modify terminal blocks for rear light/stereo modifying Etc.
Just picked up my new car which had previously had Cambridge edition rear lights, these were switched back to standard Arosa Mk2 lights for the sale, all the fuses were blown so i replaced them and they blew all over again. Different wiring. While rectifying the problem i found a load of spliced wires and it occurred to me that not many people know how to correctly swap connections in terminals so i decided to write up this little how to.
Here goes:
This is the spliced loom how i got it (bar pin 6 which i fixed before thinking about making a how to). If this mod was done the 'correct' way, it would be a lot quicker to revert and a lot neater.
Step 1:
Insert a small screwdriver or something similar to pry each end of the retainer. This block is for the rear lights, the retainer on the connector block for the radio will be a slider that pulls out the center of the block.
NOTE: MOST BLOCKS CONTAIN RETAINERS. INSPECT THE BLOCK THOROUGHLY BEFORE ATTEMPTING ANY EXTRACTION.
This will be what it looks like open:
Step 2:
Insert something into the connector block from the front on either side of the pin to compress the tabs, you should feel/hear a small click or pop, this indicates the pin should be free.
For this i used a staple from an electric stapler/nail gun.
Not the greatest picture but you can just see on pin 5 (red and black) the staple pushing down on the tabs.
Step 3:
Extract the pins and swap around. Its that easy.
A picture of the loom tidied up - all wires heat shrank up, then bound with insulating tape for water proofing and bound again with loom tape for strength.
Edited by Trx 33
  • Like 25
