Barnsley-Arosa Posted March 10, 2010 Report Share Posted March 10, 2010 You need-A large philips screwdriverA narrow flat screwdriverA large flat screwdriverFirstly you need to pop off the front of the interior handle like this:Then remove the two screws that can be seen here:Then you need to go round with the large flat screwdriver and gently prise the door card off dont be scared if it makes a few cracks its nothing to worry about.You then need to slide the lock out, disconnect the electric window switch (simply pull off) if you have them, and then un hook the door handle and pull the plastic sleeve off the handle. In this photo the black circle is the lockThe yellow circle is the wire you need to disconnectAnd then the blue circle is the hook you need to take off and pull off the door handle.Hope this helpsB-A 2 Link to comment Share on other sites More sharing options...
