Tigz™
How To: Fit a BMC CDA to a 75hp 1.4 16v
Thanks to veedub1955 for this step by step guide on how to install a BMC CDA to the Lupo/Arosa 1.4 16v 75bhp
As you can see in pic number 1 this is what you get with the kit, it includes the silicon hose and breather with it.
The kits not exactly a bolt on affair so Ive decided to do this how to
Tools needed:-
Posidrive screwdriver
10mm Socket or spanner
5mm allen key
T25 torx driver or socket
Stanley Knife
Hacksaw
Optional:
File/Grinder
7mm socket or spanner
Whats included in the kit
Basic layout of original air box
First undo the existing cool air inlet pipe, here's the first screw
And here's the next, also pull off the oil breather pipe which the new supplied breather is going to be
installed on later.
Now undo the 4 5mm allen key bolts that hold the rocker plastic cover on and remove
Now undo the 1st of the two screws that hold the air box on with your T25 torx, if you havnt got one of
these then a well fitting flat head screwdriver should undo this with a bit of care. Better pic 2 follow
Now undo the seven posidrive screw that hold the top of the air box on locations with screws in as below
Now undo the second torx screw that holds the air box on and remove air box, this is also held on by a
rubber grommet and might be a bit tight to remove
Now you have to install the reducer ring on the throttle body, here is the throttle body width
The smallest reducer supplied is a bit bigger than the throttle body and you might think it wont fit
but with a bit of care tightening it will, without any air leaks
Take care with the supplied jubilee clip that it doesn't foul the opening of the throttle cable when
screwing on
The silicon hose is bigger than you need and you will have to trim down. Mock up the position of the
induction box and mark where you want to cut it.
I always put the jubilee clip on before cutting and either use it as a guide, or use it to mark a ring right
round the hose so you get a neat cut. I tried using a hacksaw at first to cut but it didn't give a clean cut
and had loads of swarf that can get in your throttle body, so I used a sharp stanley knife and this gave
it a clean neat edge. BE CAREFUL
Now mock up hose for height of induction box, mark and cut as above
Now push the silicon hose onto the reducer, it doesn't need a jubilee clip a ) cause only two are supplied and
B ) you might over tighten the clip and break the reducer, it is a real tight fit and doesn't leak. NOW FOR THE
MOST IMPORTANT BIT CHECK THE THROTTLE CABLE CAM DOESN'T FOUL or you will either not gain full
throttle or the throttle could stick open and have disastrous results YOU HAVE BEEN WARNED. So adjust the
height accordingly
Now it is time to measure the mounting brace bar for length, mock up the mounting ring and find a suitable
mounting point as below, the cam cover screw has plenty of thread on it, so is perfect
Now cut to length with you hacksaw, Ive rounded the edges off to save sharp edges, and frayed tempers
plus its a neater job
Now install mounting bar and tighten the supplied 10mm nut and bolt to the ring, and undo the 5mm
allen bolt of the cam cover, install and tighten
NB THE INDUCTION BOX IS THE WRONG WAY ROUND IN THIS SHOT, CHECK ON THE ENDS OF THE INDUCTION
BOX AND IT WILL TELL YOU THE RIGHT WAY ROUND (DOH at least I realised before EVERYTHING was put back lol)
Now to install the supplied breather, it is a tight fit and WILL pop off a few times but you will
get there eventually :rolleyes: I cable tied round the fuel rail but didn't tighten the tie too much so
as to not crush the breather pipe or rail
Now cut to length the induction pipe and pop on, you don't need jubilee clips here as not enough are supplied
but I'm going to get some and add a a later date
Now replace the rocker cover plastic cover and go and test :shades:
Thanks for looking :rolleyes:
[nfbr's Hints and Tips]
This guide is virtually correct for people with the 1.0 Litre Lupos and Arosas too as their throttle body is also a 51mm External diameter!
Edited by nfbr
Cleaned by: nfbr.
This topic is now closed to further replies.
