Fallon Posted May 25, 2011 Report Share Posted May 25, 2011 Could anyone explain how to do an oil change on a 1.4 lupo? !!Like, what needs to be taken off to get to it, what is needed etc?Is it fairly easy?Thanks Quote Link to comment Share on other sites More sharing options...
spencesdm Posted May 25, 2011 Report Share Posted May 25, 2011 Not sure on socket size or anything but just a case of taking the sump plug off, but have something to catch all the oil and a proper way of getting rid of it. also if you take the filler cap off it will help the draining. Not a great deal of information but hope it helps you. Quote Link to comment Share on other sites More sharing options...
Mr Moley Posted May 25, 2011 Report Share Posted May 25, 2011 Google it and my guide should come up. Quote Link to comment Share on other sites More sharing options...
Fallon Posted May 25, 2011 Author Report Share Posted May 25, 2011 thanks to both!!any chance you could give me the link to your guide, as i cant find anything, it may just b me bein thick!! Quote Link to comment Share on other sites More sharing options...
Mr Moley Posted May 25, 2011 Report Share Posted May 25, 2011 http://forums.clublupo.co.uk/index.php?showtopic=78608Here you go. Should be roughly the same for a 75bhp model lupo. Quote Link to comment Share on other sites More sharing options...
Mr Moley Posted May 25, 2011 Report Share Posted May 25, 2011 Wait, thats gearbox oil, just realised you want engine oil. Quote Link to comment Share on other sites More sharing options...
maxwell Posted May 25, 2011 Report Share Posted May 25, 2011 sump plug will either be 18 or 19ml..remove that, again as above make sure you have something that will take close to 4l of oil, if your doing it yourself use a recycling bin or something of similar size.let it drain..remove oil filter and make sure you replace o rings...whack a bit of oil round the seal on the new filter and screw it down..top it up ans your away! Quote Link to comment Share on other sites More sharing options...
