DarylG40 Posted April 7, 2010 Report Share Posted April 7, 2010 Hi i got hold of a lupo a few weeks ago which had a number of things wrong with it. Last job i got to do on it is a seal on the back of the gearbox where the shift rod meets the gearbox. Ive got one on order with vw. Put the car over the pit to have a quick look today but i cant see how I'm gonna get it out. Anyone with any ideas on how to get this seal out would be great help.I did use the search but nothing came up.Thanks Daryl Quote Link to comment Share on other sites More sharing options...
HDH Posted April 11, 2010 Report Share Posted April 11, 2010 Hi i got hold of a lupo a few weeks ago which had a number of things wrong with it. Last job i got to do on it is a seal on the back of the gearbox where the shift rod meets the gearbox. Ive got one on order with vw. Put the car over the pit to have a quick look today but i cant see how I'm gonna get it out. Anyone with any ideas on how to get this seal out would be great help.I did use the search but nothing came up.Thanks DarylNot sure if its the same on the 1.0 .My OH replaced the seal on mine as it was leaking . Remove oil filler plug on gearbox . Remove oil drain plug on gearbox and drain oil . Replace drain plug . Loosen screw at very bottom of gearstick (holds selector rod on to gearstick) , pull gearstick away from rod. Drill 1 or 2 holes in old seal using a Dremel and very small drill bit . Prise out old seal . Push in new seal with something like a socket . Refit eveything and refill gearbox . Quote Link to comment Share on other sites More sharing options...
DarylG40 Posted April 12, 2010 Author Report Share Posted April 12, 2010 Thanks will give that a go.Daryl Quote Link to comment Share on other sites More sharing options...
DarylG40 Posted April 13, 2010 Author Report Share Posted April 13, 2010 Well that tip worked thanks. Ive got the part number for people who may have this problem aswell.Part number: 085 301 227Price: £6.60Thanks Daryl Quote Link to comment Share on other sites More sharing options...
Carly1990 Posted July 19, 2010 Report Share Posted July 19, 2010 Well that tip worked thanks. Ive got the part number for people who may have this problem aswell.Part number: 085 301 227Price: £6.60Thanks DarylThank you so much i need this now! Quote Link to comment Share on other sites More sharing options...
