Frankie Posted February 14, 2005 Report Share Posted February 14, 2005 Is the lupo clutch cable or hydraulic does anybody know?It seems mine is in need of adjustment i think. symptoms being bight v.close to floor and even when fully pressed gear change is not a smooth ride.hoping its cable being easier to adjust. Quote Link to comment Share on other sites More sharing options...
Snoopy Posted February 14, 2005 Report Share Posted February 14, 2005 Don't want to worry you, but there's a possibility you've got a dodgy pedal box.If the car's still under warranty it's worth getting that fixed by VW. Quote Link to comment Share on other sites More sharing options...
Frankie Posted February 14, 2005 Author Report Share Posted February 14, 2005 hmmm. i remember reading about that. not a cheap fix either.Just been searching the site for old posts about the pedal box. cant seem to find it. Can anybody tell me more? Do i remeber reading that it can be repaired by welding? Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 14, 2005 Report Share Posted February 14, 2005 have you got a gti frankie?Chech my post in maintenance, sounds to me like u got air in your clutch fluid! needs bleeding!lupo gti pedal box's r usually very strong its the polo gti edal box's that r made of plastic that have the problem! Quote Link to comment Share on other sites More sharing options...
Frankie Posted February 14, 2005 Author Report Share Posted February 14, 2005 Cheers red.Its a sport not gti.Is the pedal box still strong?I plan on sorting it tommorow.Hopefully the fluid is the problem. u say the clutch fluid is linked with brake fluid? Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 14, 2005 Report Share Posted February 14, 2005 yer, if you look at the brake resoirvoir tank, if its half full then the pipe for the clutch slave cylinder comes off of it half way up! thus meaning that when it falls below that it will start sucking in air! style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" />needs a good bleed! look in the ''how too'' section for info on bleeding clutch!! Quote Link to comment Share on other sites More sharing options...
paulbin Posted February 14, 2005 Report Share Posted February 14, 2005 i think the sport has a cable clutch Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 14, 2005 Report Share Posted February 14, 2005 i know that the tdi has a hydrolic one! Quote Link to comment Share on other sites More sharing options...
g40steve Posted February 15, 2005 Report Share Posted February 15, 2005 Hi Sport is cable 1.4 petrol.Self adjusting? This could be your problem as they sieze up.Follow cable from gearbox back to bulkhead, large bulge about half way is adjuster, should be held in a cage.Ask VAG they should know.Steve. Quote Link to comment Share on other sites More sharing options...
N13CAH Posted February 15, 2005 Report Share Posted February 15, 2005 Mine went back to the garage 2 weeks ago to get the clutch adjusted.Couldn't always get it into second gear and biting point was nearly on the floor.Seems fine now. Quote Link to comment Share on other sites More sharing options...
Frankie Posted February 15, 2005 Author Report Share Posted February 15, 2005 Sounds similar to my problem being as biting point is about on the floor. seems worse today. selecting reverse without grinding is impossible and 1st is a bit of a b**ch. Local mechanic is taking a poke around in the morning. i havnt mentioned anything about pedal boxes and the such like, will leave it up to him to see what he comes back with.cheers guys, will let u know how i get on. Quote Link to comment Share on other sites More sharing options...
Frankie Posted February 16, 2005 Author Report Share Posted February 16, 2005 Had the loop looked at today. It is a cable clutch. Clutch needed adjustment, it is quite worn. So its cost me a tenner and w'ere runnin smooth again. Just a different biting point to get used to now. Quote Link to comment Share on other sites More sharing options...
N13CAH Posted February 16, 2005 Report Share Posted February 16, 2005 Glad its working ok now. Quote Link to comment Share on other sites More sharing options...
