PaulEd Posted September 26, 2007 Report Share Posted September 26, 2007 just bought a sub and amp from motorworld, fitted it all wired it up etc, but nothing! dad got this machine to test for power etc its all going into it but nothing seems to be happening on the amp! no power light or anything coming on.. im so annoyed/upset! taking the loop with sub in to the shop on friday to see if they can sort it out for me! i want some basssss! rant over! Quote Link to comment Share on other sites More sharing options...
Gavs_arosa16v Posted September 26, 2007 Report Share Posted September 26, 2007 It might sound dumb but have wired up the remote wire from the head unit to turn it on. Quote Link to comment Share on other sites More sharing options...
PaulEd Posted September 26, 2007 Author Report Share Posted September 26, 2007 It might sound dumb but have wired up the remote wire from the head unit to turn it on.the one going from the antenna bit to the amp? if so we touched both ends on the metal and nothing happend still Quote Link to comment Share on other sites More sharing options...
Gavs_arosa16v Posted September 26, 2007 Report Share Posted September 26, 2007 Thats the one. I had trouble getting mine to work, Im sure I had to use a different wire in the end. Basically its any live feed thet comes on when the radio is on, otherwise it will be on all the time draing your battery.Also check the fuses on the amp and main power feed, its easy to pop one wireing it up. Quote Link to comment Share on other sites More sharing options...
PaulEd Posted September 26, 2007 Author Report Share Posted September 26, 2007 ahh nice one matey, will try tomoz when its light again! checked all the fuses they are fine.. hopefully its just that wire! cheers Quote Link to comment Share on other sites More sharing options...
Daz_Wilko Posted September 26, 2007 Report Share Posted September 26, 2007 You checked you have a good earth/ground contact?, mine uesed to come on and of randomly so changed my earth point and worked fine after that.and your remote wire is usually a thin single blue wire that connects to you headunits wiring. Quote Link to comment Share on other sites More sharing options...
PaulEd Posted September 27, 2007 Author Report Share Posted September 27, 2007 You checked you have a good earth/ground contact?, mine uesed to come on and of randomly so changed my earth point and worked fine after that.and your remote wire is usually a thin single blue wire that connects to you headunits wiring.yep checked the earthing with those wire things dad had it was all fine, yeh the wire is thin and blue, just abit akward as i dont really kno how it should fit in as it is the Y shaped fitting and has to somehow go into my antenna bit?! Quote Link to comment Share on other sites More sharing options...
