LOOPTY-LUPO Posted September 28, 2006 Report Share Posted September 28, 2006 First take a spider tool to the lower two bolts of the arch liner and remove them.Do the same to the other side.Remove the other 2 (slightly larger) spider toool bolts which are square on to the bumper (easily viewable from the front).Open the bonnet.Real deep into the bumper (from inside the bonnet on the left hand side) you can see two catch locks: undo them!!From underneath the car, you can see x4 plastic/rubber rivet holder "thingys" holding the bumper to the other section of the bumper, stick yourfingers underneath and whip em' undone.Now that you have removed part of the arch liner, you can put your hand up from underneath the car and into the arch and start unclipping all the latches from the higher part of the lower bumper.I think there is about 12 (not too many), don't worry.Give the bumper a clean with fairy liquid (FOAM) - haha then take a shower because you'll be filthy!!!EWW!!!!Thanks for looking!Dallan.PLEASE NOTE THAT THE BACK BUMPER IS ALL 1 PART SO NOT REMOVABLE UNLESS YOU TAKE THE WHOLE THING OFF!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
