Lupo G60 -> vRS 1.8T
Petar
I wanted to put this at project cars but I can't post there.
Here will be lots of useful infos and pics
My Twin V6 Lupo is finished now so I started engine conversion to my daily Lupo.
I have it one year. Till now I just fitted cheap coilovers , Audi A2 polished wheels (redrilled hubs to 5x100) and a pair of A3 recaros.
It was really slow. I bought few engines for it (first 1.8T but it was damaged , then 2.9 VR6 and 16V ABF) but I sold them. I found good G60 1H engine out of rallye golf and started this :)
Few summer pics :)
G60 fits Lupo same like Opel od Ford engine :D Nothing fits :ph34r:
photobucket.com/albums/m167/TASV6/Lupo/DSC00230.jpg
Edited by Petar
seriously petar is there anything you cant do, this must be the first G60 ive seen strong work!
you are like a freakin god. well done very impressive. oh and on behalf of everyone here, thank you for choosing to work your magic on the brilliant Lupo. ps more vids of the twin v6 on youtube please. that launch video is such a tease i want to see it going flat out :o
Brilliant, That will be a fun car to drive, be it not as fun as the twin, but more practical!
I was supprised, i thought there would have been more room for the enigne in the bay, i supose its because you have the exhaust and inlet manifolds on one side and the charger on the other, must make the engine quite deep.
John
John
Yes, it's very tight. I already cut piece of subframe because gearbox is much bigger than 1.0 (1.4) gearbox
Manifolds aren't problema :)
What would you charge to supply me with the mounts??? With your mounts wud it make it a straight drop in??? Obv apart from
notching subframe for box, then just pipes exhaust and wireing to sort out??
Subframe is 15 min work :)
People here say that you need custom driveshafts.
I found that Lupo 1.0 (1.4) right driveshaft fits perfect and for left driveshaft I will use right rear from Mk3 VR6 syncro!
Fits perfect on early passat 1.8 cable change geabox with 90mm inner CV joints. :)
  • Like 2
Engine cleaned and completed
Passat 1.8 gearbox . Shorter gears than G60 , max speed 225 km/h on 195/45-15 . Audi A3 1.8T shifting mechanism.
Longer driveshaft is OEM Lupo 1.0 , shorter is REAR right from Golf VR6 syncro :wacko:
This gearbox has 90mm flanges and these driveshafts fit perfect!
No more driveshaft kicing
Oilpan is sooo low...
Chargecooler
