bossjohnc Posted August 9, 2005 Report Share Posted August 9, 2005 Thanks to VR6 Lupo for this one:take off the handle by pushing the "square" button in on the handle near the pivot point and pull the handle off, take the pannel off behind it by removing the screw, slide the pannel towards the rear of the car and it should pop off with some light persuasion, you will see the bonnet release mechnism, un screw the mechnism from the body work i think there 2 or 3 screws, in the back of the mechinsm there is a screw where the handle pivots, you need tighten this screw up, then every thing should be fine and dandy, once you put every thing back together by reversing the process. Link to comment Share on other sites More sharing options...
