All Activity
- Past hour
Tripod started following My knob keeps slipping out
My lock knob keeps disappearing into the door, I thought after 10 years of ownership I should probably fix it. I need to get one of these that is not broken: Does anyone know if it has a part number? Or have one kicking around somewhere that they don't need?
- Today
woodyrvf750 started following 3L Front Spring wanted - 6E0 411 105 F - 3 grey 2 green markings
Marinawhb joined the community
- Yesterday
Frank, send me an address and I'll send you some ball joints.
More work today - condenser in over lunchtime but left sealed as it included the dryer. Once the compressor is in, I'll arrange to get the system gassed up and then close everything up and mount the bumper again before leaving for the workshop. Photo included also shows the somewhat reluctant headlamp washer mounting screw that had to be ground off - to be replaced with a stainless hex screw when going back together... The other side was perfect. The ESP sensor for the steering column is ready to go back on after refurbishing in Germany - still to arrange with a local agent to complete the set up of the software. With the wheel arch liners out, I can see the underside is completely like new - no corrosion at all. I replaced the side indicator bulbs as the orange coating had failed on one side. After this, I think a Bluetooth installation to get streaming and a USB connection in one of the blanks in front of the gearlever. Then it's finished - I hope...! Paul
Come on don't be shy with some pictures of your GTI.
matt s joined the community
as per title looking for the 3l steering wheel in grey if anyone is holding one in a dusty corner?
Tallika_Fan started following GTI 3rd party Ball joints
I'm awaiting new suspension but I have new ball joints to go on so when the old ones come off i'll do some comparing.
- Last week
RobertVef started following 1.4 tdi AHF Strange Coolant Temp Issue
rhvsb joined the community
Following on from above, since all my parts arrived, it's been raining constantly here so no install yet! When the time comes to fit the refurbished ESP steering sensor, do I have to have someone flash the software immediately before driving it or can I fit it then drive to my local VW independant and have them reset the system? Thanks Paul
I changed the coolant temp sensor from genuine to aftermarket (green one) about 2 years ago as needle was jumping 0-90-issue resolved. 1 year later I noticed coolant leak from the sensor, changed for a new (aftermarket)sensor as I couldn't get the o ring separately-seal fixed but now only going 70c on the gauge. Foolishly I had binned the old working one but I thought I just had a faulty sensor so got a new one under warranty, changed this still the same issue. Was going to put a genuine temp sensor in place however I thought I would just change the thermostat too as it was old & maybe I had gotten unlucky for both issues to happen at same time, fitted new non genuine thermostat in (I know!) & the gauge is now going to 90c on the dash after say 7-10miles-Issue fixed I think. The 1st long run I went (150miles) the 1st 20miles the gauge is stuck to 90c as it should, after that it drops down to 70 & even goes below so I am thinking the coolant temperature sensor is faulty however at the end of the journey I check the temperature of coolant in the expansion bottle using the Mrs cooking thermometer & its 67c. Now when doing short journeys its not getting to 90c as it was when I had just changed the thermostat, the hottest i have gotten the coolant in the expansion bottle is 72c & I the range of the sensor is supposed to be 75-92c from what i can find online (so it sits at 90 on gauge). So is the thermostat stuck open & causing issues or do i have a faulty sensor? Can't find my infrared gun to check temperature of coolant at sender location which is helpful🤦♂️. Before I go waste £65 on a genuine coolant sensor is there anything else it can be or have I missed something? Car is still running fine & giving heat through vents. Cheers.
There are unofficial sites that have versions of ETKA on them, though how up to date they are I don't know. The dealership I work for pays for ETKA as it's a VW/Audi/Seat/Skoda parts catalogue and meant for dealership use only
99problems joined the community
Ah well, I guess I'll make a best guess with measuring it and seeing how it goes... I had to grind the head off the nozzle securing screw on one side - as expected, reading the forum - so will use a stainless hex-head screw to replace it and grease up the other side... Thanks for the info - is ETKA available to all, even as a paid service? Paul
I've looked on ETKA and it is a seal that only comes with the whole unit, which is a pain as they are obsolete from VW now.
Paul64 started following Headlamp washer sliding tube o-ring
Good morning all, Does anyone have an OEM part number (or new o-ring dimensions) for the seal on the extending part of the headlamp washer nozzle unit? I'm just refitting a new A/C condenser and compressor to fix a leaking heat exchanger and, replace a 20-odd year old compressor seal whilst everything is in bits. I do however, need to replace the o-ring in the nozzle to stop a leak from there when it's used but the old one is too worn to measure correctly. Is there somewhere online a parts catalogue for the Lupo that people are using?? Thanks! Paul
Just keep checking/topping up through the speedo pickup hole... cheap and cheerful solution that buys you time.
If anyone has an old gti ball joint and a set of calipers, can we do some measuring? We might be onto something here that'll help gti owners the world over...
Diff Flange Green Sleeve
BlobbyBrown replied to BlobbyBrown's topic in Car Care, Maintenance and Mechanical
For those looking at this; I changed out the oil seal at the weekend. The oil seal sits at the front of the green sleeve so if the sleeve is excessively damaged then you will most likely need a new sleeve. You can remove the oil seal without removing the green sleeve. Mine [the sleeve] was damaged but managed to refit with a new seal; hopefully no more leaks, but we'll have to monitor as the outer edge of the oil seal was showing in places. I did order a new sleeve for a POLO from the US but it doesn't arrive until June! (now April), so hoping it all holds out until at least then. Regards Rob -
The part numbers on the 9N ball joints are 6Q0 407 365M and 6Q0 407 366M Which is very similar to the Lupo Gti part numbers of 6E0 407 365 and 6E0 407 366 Although admittedly i'm no expert on the part numbers and what each letter/number represents, would this not suggest that they are pretty much one and the same? They do look identical to me
East Coast Bmx started following Head Light Ballast Wanted...
Lupo gti Drivers Head light Ballast Or Complete Head Light...
Frankcow joined the community
spavtopoody joined the community
Dayanawheed joined the community
Brilliant thanks for that,I'll give it a go 🤙
Oh is that one of yours ?? I'm sure I used your SDI cam belt how-to. Really well written so thanks for that 🤙
Brilliant thanks for the advice guys all went well. However seems like I've managed to mess the tracking, camber and caster angles.. how do I get them back in the ball park so I can get it set up properly.
