Removing a Lupo Drivers Door
rapidebrothers
Basically had an accident with my Lupo where my door has been damaged so wanting to replace it with a good used replacement.
But need info on how you remove a door & what tools / procedures you go through to do it?
Thanks
Don't know for sure but, shouls just be a case of removing the door card and electrics from window reg (if fitted), central locking and speaker.
Then remove the check strap, then undo the bolts for the hinges.
Sounds bout right
Removed both door panels but now struggling to remove electrics wondering which cables to dissoconnect so it can be thread threw the door so it can be removed from car
Any more help?
Found where the electrics for the door need disconnecting....it's behind the panel where the bonnet handle lever is in the drivers footwell!
