katierouse20 Posted October 3, 2014 Report Share Posted October 3, 2014 Hello I'm tying to fit a sub. All is well except running the power trough the bulkhead. Where can I get it through nice and easy? I couldn't see anywhere behind the footwell carpet. It's a 2005 1.4 sport 100bhp..Also, where can I find an adapter for the door components? I'll get the standard paper speakers drilled out ok, but need some sort of fitting ring? Quote Link to comment Share on other sites More sharing options...
Skezza Posted October 3, 2014 Report Share Posted October 3, 2014 There is a hole in the engine bay. You probably won't spot it unless you look carefully. I only found it when I popped the bonnet at Matt's and just caught a glimpse of it. You should see it though. You can feed into there. Quote Link to comment Share on other sites More sharing options...
katierouse20 Posted October 8, 2014 Author Report Share Posted October 8, 2014 where abouts? Quote Link to comment Share on other sites More sharing options...
