ChrisHallam Posted August 2, 2014 Report Share Posted August 2, 2014 My EML came on today and didn't go off. It was quite difficult to set off and it was 'stuttering' in every gear. It's came on before but went straight off. I have no idea what it could be and if anyone would be able to give us an idea that'd be great. I know this is could be a range of things but I can't really narrow it down anymore as I daren't start it.Thanks Chris. Quote Link to comment Share on other sites More sharing options...
mattarosa Posted August 2, 2014 Report Share Posted August 2, 2014 Your best bet is find someone local to scan it, failing that buy an obd2 scanner. 1 Quote Link to comment Share on other sites More sharing options...
danoid Posted August 5, 2014 Report Share Posted August 5, 2014 Could be sparks, plugs, coil pack, engine speed sensor etc etc. Quote Link to comment Share on other sites More sharing options...
ChrisHallam Posted August 6, 2014 Author Report Share Posted August 6, 2014 Aye the obd2 found a cylinder 4 misfire with a code of p0304 and found two of my spark plugs had cracked, so luckily its an easier fix than I thought. Quote Link to comment Share on other sites More sharing options...
