1.4 TDI Boost gauge
Ant0889
I was given a free boost gauge by a friend who upgraded, and I wanted to fit it to my Arosa
As all the pipes on the TDI seem to run vacuum I'm not too sure how to plumb it in.
I did a search and found this link but all the pictures are dead :(
http://forums.clublupo.co.uk/index.php?/topic/10111-14-tdi-boost-gauge/page-2?hl=+boost+gauge
I then followed the link from that threas and found this ...
http://www.a2oc.net/forum/showthread.php?10298-TDI-Boost-Gauge
which suggested the use of this Revotec self installing nipple...
http://www.revotec.com/acatalog/Push-On_Tail.html
has anyone used this before or got any idea how/where to install it?
cheers
I've fitted one to mine, I've just drilled a hole in the top inlet pipe then tapped it so that I can but a connector in, then I've just ran a thin rubber pipe in to the car through the bulk head then up to my center air vent, I don't know how to post pictures to show you or I would
