Boot window seal
Is this part replaceable? I have to remove the window so i can clean all the corrosion and paint fresh, but i want to know if the seal holding the window can be ordered from VW.
Maybe someone knows the code?
Thanks!
Better put it, how did people with rust under the wiper, managed to clean and repaint it, w/out removing the glass? Because i can spot a small seal right under the glass.
