Ralphch97 Posted May 17, 2014 Report Share Posted May 17, 2014 Hello, sorry if I have posted in the wrong place, I'm new to this!My VW Lupo 1.0 has a whining noise when being driven, in neutral on stand still the is no noise, also when the clutch is pushed down the is no noise when being driven.The noise occurs straight from pull off and then gets louder as I progress up the gears.On a previous mot advisory when I didn't have the car, the was an advisory saying gearbox noisy, and on my mot 5 days ago, I got advised on exhaust manifold gasket, I know that might not be relevant but...Does it seem like a gearbox fault? Release bearing? A bearing gone?Help please, I'm fussy with any little noise!Thanks - Ralph! Quote Link to comment Share on other sites More sharing options...
Karl_Mac_ Posted May 17, 2014 Report Share Posted May 17, 2014 Sounds like your gearbox is tanked. Difficult to say what it might be without seeing it. Quote Link to comment Share on other sites More sharing options...
Ralphch97 Posted May 18, 2014 Author Report Share Posted May 18, 2014 So I will pretty much need a new box most likely!?Will it be okay to still drive? As I need it for work Quote Link to comment Share on other sites More sharing options...
Nathan94 Posted May 18, 2014 Report Share Posted May 18, 2014 Try record the noise and post it up? My gearbox went without much notice, started whining on the motorway, I knew what was coming, few minutes later, dead.If it is the gearbox and it does good it should be able to see you home with a lot of swearing, smells and noise! Haha Quote Link to comment Share on other sites More sharing options...
arosaSDI Posted May 18, 2014 Report Share Posted May 18, 2014 that's the box. my sdi did that before a lot of crunching and the shaft breaking in the box Quote Link to comment Share on other sites More sharing options...
