Will they fit?
Andyhealy96
No I had the same idea as they would look bang on, but the bore is smaller on the alloy then then hub on the lupo, only option would be get the extra bit machined off professionally, but with the cost of that may as well get different wheels. I wanted some in white :(
There's been a few people running BMW Mini wheels now. Did they change the stud pattern as I don't remember issues before; apart from the centre bore that is..
New Minis are 4x100. And 56.1mm centre bore, if I remember correctly. 0.5mm around the circumference of the centrebore? That's nowt. A little bit of sanding would sort that out pretty quickly I would have thought.
And it's BOUGHT!
