wiring new front speakers and amp
Hi guys, I've just had a go at wiring in new front speakers and amp. Specs are thus: hertz dieci dsk 165.3 components 4ohms, SPL dynamics 150.2 2 channel amp, 4 gauge auto leads wiring kit.
Wired everything in, fired it up and it seemed OK. I turned up the HU and when it reached a certain volume it all cut out. Turned down, it came back on, turned up and it cut out again. Any ideas what causes this? Its grounded to that circular lid under the back seats and the remote cable is spliced and soldered to the blue wire in the HU loom.
On a side note, the live came loose and blue the amps fuse so we disconnected the battery, new fuse in, fixed the live, batter back on and the amp fuse blew immediately. Again any ideas? So confused, everything seems to be wired right :/
your amp will be giving too much power, turn your system all the way up (should cut out) then go to your amp and turn your gain down until it turns back on
