GTi Xenon Ballast Info/Part Numbers
sambo28
I need the passenger side ballast replacing on my GTi and was just wondering if one from a drivers side light would fit?
I had a search and couldn't find any part numbers for either side so any information would be greatly appreciated!
Thanks in advance.
I've found someone with a spare drivers side headlight for sale, I was just hoping I could buy that and use the ballast from that with my passenger side light.
That probably explains it a bit better, so will the drivers side ballast work with my passenger side headlight? ie. are the drivers side and passenger side ballasts identical and interchangeable?
Edited by sambo28
Yes thats correct mate, was in the same situation a little while ago but i couldn't get the torx screws on the ballast undone as they had all rusted
Thanks mate, much appreciated! I'll get this drivers side headlight bought then, whip the ballast out and get it fitted fo my passenger side headlight!
